    • By NC4wd
    • By Kingfish
      This is the 2020 updated version from the previous 2009 version.  I do not know all the differences.  I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
      HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
    • By Robert Scott
      I've had a Hisun HS500 (Axis 500) that I bought at Lowes almost a year ago.  I have downloaded the service manual found on this forum and notice that they have 2009 and 2010 year dates on them.  Isn't there a newer version available somewhere?  I'm about to try my first ever valve adjustment and am wondering if the info is the same.  Mine is fuel injected but there is carb info in those manuals.  Don't know if they still have carb models now but figure they did then.
      Bob
    • By strike250
      Matt
