I was reading through an old thread about the woes of the risky ownership of Hisun UTVs. Well, OK. So we all own some problematic machines. But I’ll say this. I’ve owned bicycles, automobiles, snowmobiles, PWCs, boats motorcycles, class 8 trucks, airplanes and a crapload of heavy equipment. Nothing I’ve owned and operated hasn’t broken or needed maintenance. The difference between all those prior items and my Hisun, I feel, is the support (or lack of)from the factory and dealership. That’s where this and other forums come in. We’re all we have! Well, us and YouTube. Oddly enough though, with help I’ve received from YouTube and you guys,I’m actually starting to enjoy crawling through this machine, and screw the factory/dealer. I’ll make this vehicle what they didn’t. And have fun doing it.
  • Like 3
  • 5 weeks later...
That's exactly what I did......couldnt get warranty work,, couldn't sell it..so with some higher quality parts mixed in, it's now a decent SXS...But Massimo/Hisun still sucks as far as I m concerned.
    • By hisun junk
    • By Justine
    • By A P
    • By shawn b
