T2 Light bar width
By felo72
By camojay
1400 miles on it
20240817_133539_1.mp4
By Chile
I have a 2018 Massimo 700 MSU with the Delphi MT05 ECU.
I have seen an alternative ECU reset procedure that involves running the engine at WOT for 5 seconds in neutral and then shutting down while throttle still at WOT. The articles include comments that the rev limiter will prevent engine overspeed ad attendant damage.
1. Is this actually a recommended procedure for restting the ECU on a 700 MSU?
2. What is the rev limited maximum RPM for the 700 MSU?
I initiated this procedure but when the RPM exceeded 6000 I immediately terminated the process. It simply seemed excessive to me to continue.
Any and all responses are greatly appreciated.
Chile
By Steve R
after looking at the diagnostic procedures in this forum, I am finding my Gunner 250 does not have an engine warning light on the dash. i have tried to see if any other symbols flash, but nothing seems to project an error code. i have not engine spark. I do not get a start of the fuel pump. I have replaced the ignition coil, the ECU (MT05) and the voltage regulator. I could really use a diagram for the 250 model. i need a place to start checking the electrical system.
By CarlB
I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential. I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
