What's the width of the tabs on a stock cage ? Also maximum width of the main hooo before the bend ? I forgot measure this weekend, troopers 250 miles away and was too busy pulling the diff before I left
Sent from my SCH-S968C using Tapatalk
    • By tskm
      Tom
    • By felo72
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
    • By Chile
      I have a 2018 Massimo 700 MSU with the Delphi MT05 ECU.
      I have seen an alternative ECU reset procedure that involves running the engine at WOT for 5 seconds in neutral and then shutting down while throttle still at WOT.  The articles include comments that the rev limiter will prevent engine overspeed ad attendant damage.
      1. Is this actually a recommended procedure for restting the ECU on a 700 MSU?
      2. What is the rev limited maximum RPM for the 700 MSU?
      I initiated this procedure but when the RPM exceeded 6000 I immediately terminated the process. It simply seemed excessive to me to continue.
      Any and all responses are greatly appreciated.
      Chile
    • By Steve R
      after looking at the diagnostic procedures in this forum, I am finding my Gunner 250 does not have an engine warning light on the dash. i have tried to see if any other symbols flash, but nothing seems to project an error code. i have not engine spark. I do not get a start of the fuel pump. I have replaced the ignition coil, the ECU (MT05) and the voltage regulator. I could really use a diagram for the 250 model. i need a place to start checking the electrical system.
