Diff upgrade help
ERV JR
Ok guys I tore my diff apard anfrer shearing the ring gear bolts. Drug my butt after rearing it down, yesterday while placing a McMaster Carr order I searched the board for the part number and added the bolt s to my normal order. They showed up this morning and I realized they are long , really long. I grabbed a set of calipers and mic'ed the carrier and ring gear and come up with about 16mm in length.
So the question is why in the worldvare the bolts that folks talk about 40mm long ? Are you guys ordering them long so that they have a shank at the top where they go thru the carrier & cutting them off ?
Sent from my SCH-S968C using Tapatalk
Yes!!! that is exactly the reason. I am the one who started the act of using these bolts, my reasoning being that the thread acts as a place for the bolt to start shearing, just cut them all to length and remember, you have to grind the head down also, I think I posted a photo of that also.  to grind them down, I used a drill and a grinder, and I never did agree with those who put nuts on the bolts,
AND while you have access to the mating surfaces, sand them so the locktite has a little more to grab onto when you apply it to all the very clean surfaces and bolt when you do your final assembly.
did you find any instruction on how to do all this or have they been lost?
Jeff
Jeff I didnt find any instructions. I cut the bokts to legth and shimmed the pinion to sit as deep as possible. I realized why these diffs break. They are junk. Lol . I can't shim the carrier to adjust back lash. Well without maching the case to allow for the carrier to move
2 hours ago, ricksrb said:
I have a copy Lenny sent me back in 2010. Hopefully you can open it.
Joyner Trooper Dif Kit FINAL DRAFT.doc
BEAUTIFUL!!!! THANKS, I have added it to Parts, Pieces, and Information for our Troopers & Joyners as
Joyner Trooper Differential Rebuild Kit .doc, figured it would show up in searches better with that name.
Ah man now the direction come out, too late for me. The lousy part was I spoke to Silver bullet and he said he had never heard of anyone shimming the spider gears. I had planned to do that just like I do in other diffs. I sorted thru my shims and found what was need to shim the pinion but didn't see any shims behinde the bearing on the carrier to tighten backlash anymore. Now I wish I just went with my plan and shimmed the spiders. I could have ordered plenty of shims. It is better but not ideal. Hopefully it lasts another few years an I can reset up as I'd like later. Bad thing is I tigged the spider gear shafts to the carrier as per Silver bullet but I could easily dress the weld with an endmill and pull them out
    • By GWS
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
    • By Buck
      My father-in-law has a Hisun 750.  It has started to not change gears while running.  He can turn it off, change gears, then restart and it will change.  I thought it might have something to do with the brake but can’t find any info.  Thanks in advance for any info.
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
