Hisun Sector 250 oil dipstick?
By CapnWalleye
Â
By Gorj
I am going to replace the batteries in my E1. I am not interested in the high cost Lithium or the expensive 6 volt dry batteries. I am considering four 12 volt deep charge marine batteries. I have a source for 810 amp units for about $100 each. I have no worries about reprograming the charger because it went out a few years ago and I replaced it with generic golf cart charger. When I decide to do this, I'll keep you posted on the results.
Is there a code reader available for the Coleman UTV 400? I tried using the HUD ECU Hacker software and cables/adapters but no luck OBD to delphi 6 pin and KKL VAG as well as ELM327. Will not connect. I was able to get it to connect randomly a couple of times, but haven't been able to since. I was able to clear and read the codes briefly. I'm aware of the Tiny Scan 301 but it doesn't seem to be readily available. There's a few out there but they are expensive. Â
By Marie
hello, i need help figuring out where all these wires go on this battery. I can't seem to find any pictures diagrams. As to what should or shouldn't be attached and where these two plugs go, that aren't plugged in. this was got as a project. would run then die and battery would have to be jumped off to start again stator has now been replaced but any help with this wiring would be appreciated.Â
By Marie
