09 Mule drive issues
By Off Grid Refugee
I have a yanmar longhorn 6 seater which I believe is having fuel delivery issues. It will run off of starter fluid and will sometimes run on gas but will not idle. Fuel pump is new and verified to put out 56 psi. Injector is new, I'm reading 10.5 volts at the injector, gas is new. The unit will run when the engine symbol is not present at the gauges. Diagnostic port doesn't appear to be present, can't find it where yanmar says it should be. Oil is full but old. Any ideas what's going on here? Is there a maintenance function that will shut this machine down if it has old oil?
By Jim D
MSU 500 does nothing when you turn the key. No power to display, fuel pump or anything. Come back a while later and everything works perfect. Starts right up. Battery is fully charged. Could this be the ignition going bad. When it doesn't power up I've found nothinf that will correct it other then waiting and trying later.
By BernieG
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
By Michael Wood
I have a 2018 Massimo Buck 400 with 278 miles.
Having issues with my brakes. Took the buggy hunting and when I let my foot off the gas pedal it pulls without pressing on the brake. I looked and the pads on all 4 wheels are all toast. The E-Brake hasn’t been on since I have had it. I am guessing it may be a master cylinder issue because all 4 pads are gone. They all seem to have worn evenly that’s why I think the master cylinder. Just got the machine used from a older couple and they said it sat for some time in there pole barn. Possibly the brake lines? Calipers? I took one brake apart and when I depressed the caliper it didn’t stay. Any help is muck appreciated.
By donny
