The rear gear box has a big hole in it were the drive line enters. The engine runs well and it has chrome wheels .
what on earth should I do with it ?
Any ideas would be appreciated !
You have a few options depending upon its age and general condition.
1.  Replace the differential
2.  Sell it as-is
3.  Part it out.
4.  Weld a patch over the hole (if the differential casing is weldable).
We can't really decide for you.  We can only give you options.  Probably #2 or #3 because of it being 11 years old unless you can get a free or very low priced differential.
Thanks for the reply.  I called Disabled Veterans and they will come pick it up and I can write it off my taxes next year.  Bad experience but that's just the way it goes sometimes.
Thanks to all who tried to help  !
    • By Ductking1
    • By Justine
    • By mark walkom
    • By tskm
      Tom
