UTVBOARD Updates Completed
By Alex
This is an interesting read. ADAS is main stream on cars these days. The technology looks to be headed towards UTVs and Off-Road Vehicles.
Potential Motors and CFMOTO USA have announced a new partnership to integrate advanced driver-assist systems (ADAS) into recreational off-road vehicles for the first time.
Sam Poirier, CEO and co-founder at Potential Motors, says the integration of its technology into CFMOTO’s vehicles will set new standards in the side-by-side segment. (Photo: Potential Motors Inc.) The partnership will first see Potential’s tech integrated into CFMOTO test vehicles. The companies will conduct extensive real-world testing at Potential’s purpose-built off-road proving ground in Fredericton, Canada, and CFMOTO facilities.
Source: https://powersportsbusiness.com/top-stories/2023/12/19/cfmoto-and-potential-motors-announce-industry-first-adas-technology-for-ohvs/
By FGT
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By Chile
I have a 2018 Massimo 700 MSU with the Delphi MT05 ECU.
I have seen an alternative ECU reset procedure that involves running the engine at WOT for 5 seconds in neutral and then shutting down while throttle still at WOT. The articles include comments that the rev limiter will prevent engine overspeed ad attendant damage.
1. Is this actually a recommended procedure for restting the ECU on a 700 MSU?
2. What is the rev limited maximum RPM for the 700 MSU?
I initiated this procedure but when the RPM exceeded 6000 I immediately terminated the process. It simply seemed excessive to me to continue.
Any and all responses are greatly appreciated.
Chile
By Stan Morton
My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850. If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance. Kind Regards, ~ Stan
