Parts for sale: 1100 short block, tranny, diffs
By Kingfish
By Ridge Runner
thanks
Ridgerunner
By WCF
Hi Joyner Gang
By Quentin Walker
Hi all. I am in dire need of some help. Through our university, we are competing in the Baja SAE competition. It is a collegiate engineering design competition to design and manufacture an off road dune buddy.
To cut to the chase, we were donated a 2011 Hisun HS 700 UTV, and we are using suspension and drivetrain parts off of it in our design. I am in the process of ordering new parts, but I am coming to a standstill.
Does anyone have any experience ordering parts for these machine?
From what I have found online, these machine were sold by Tractor Supply, along with a few different brands that share the same parts (Supermach, Coleman, Massimo, etc.)
Any help is appreciated. Thanks in advance.
