This thing was great in the flats for the kids at Buttercup this weekend. My son rolled it, and everything held up really nice with the exception of a UV joint on the steering bar. Easy fix with a Yamaha Joint. 00524347e562bf30581e452a9d755636.jpg05061d233d33e330ef5418e6c2bc1aa6.jpg
Sent from my iPhone using Tapatalk
    • By Paul in Wisconsin
    • By A P
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Cletus
