New Accessories for Sector line up
strike250
Hello there, just to keep those who own the Sector model up to date.  We are working on  lift kits now for the Sector line up, for all engine sizes. We are also working on more, like storage boxes for the Sectors as well. We are also building trailer hitch set ups for the Sector 250. We are working on seat belt by pass connectors and rear light/license plate light connectors for the OEM connector in the rear. Keep an eye on for more accessories at our website www.250utv.com
Please let us know if there are some things you are looking for that are hard to find. We just might make it for you!
Matt
  • 4 years later...
    • By Kingfish
    • By Woody77
    • By A P
