The RTV400CI/RTV500 is part of Kubota's Mid-Size Utility Vehicles. The EFI gas-powered 4WD RTV400Ci and RTV500 feature mid-size utility, agility and the legendary Kubota reliability you need to get the job done. There is a special financing offer currently running as well.
Big Performance: Compact Design Loaded Value
Full Brochure: https://www.kubotausa.com/docs/default-source/brochure-sheets/rtv500.pdf?sfvrsn=e197ac2b_4
Kubota RTV 400
Kubota RTV 500
KUBOTA RTV SERIES - NEW PURCHASE SPECIAL OFFERS
0% A.P.R. for up to 36 Months on your new RTV400/RTV500 Series RTV! (offer ends 06/30/2018)
0% A.P.R. for 36 Months with 0% Down1 OR
0% A.P.R. for 48 Months with 0% Down1 OR
1.99% A.P.R. for 60 Months with 0% Down1
OR
$300 Instant Rebate for Cash or Standard Rate Financing
    • By Paul L
    • By Grant
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
