Quick question about replacing the plug.  One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs.  15amp 125v?  Is it more complicated than that?  I do plan to buy a plug that's water tight.
Thanks in advance!
Yes, just a standard heavy duty 15a plug. It can run a little warm, so stick to heavy duty hardware.
I actually completely replaced the end of mine by running it to an RV type receptacle I mounted on the right side.  Just cut off the plug and wired it to the receptacle.  Now i just plug an extension cord into the side of the UTV.
    • By Edelbrock
      Thoughts?
    • By Xov
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By SpaceGhost
