  • Alex pinned this topic
    • By Marie
    • By A P
      I have a 2022 hisun sector eps 550. 30amp fuse is blown for eps. Checked the motor and itā€™s fine. Opened up the controller and found a bad diode. Dealer wanted 500$ for the controller. Just posting this in case it helps someone. I couldnā€™t read numbers from the old one so just took a guess and replaced it with a 100v 3amp diode.Ā
    • By clint501
    • By SteveS
    • By tuell
