  • Alex changed the title to hisun 750 Service Manual
Oh, okay i get ya'.
https://www.tradebit.com/filedetail.php/276553349-hisun-500-700-utv-efi-workshop-service-repair
This might be it, but it costs 15.00 USD
nevermind, that's for a 500/700 :(
  • 4 years later...
    • By hisun junk
    • By Justine
    • By Jacob E freeman
    • By A P
    • By Gerald Mohs
