For the Sector and Strike 250's. Hello there, we are now stocking the electrical connection to the rear plug that allows easy aftermarket installation for lights, light whip or more when the key is on. No more cutting into the factory harness to find the right wire to use. With this plug, you can tap it into your accessory and simply plug into the OEM harness. Weather proof connector. Can also be used for a license plate light on the street legal registered units. Comes pre-wired with correct color code. (photo not showing actual plug)
    • By Gorj
    • By A P
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By Joseph Sills
