Trail jack
By Jon V
By mac66
By Buck
My father-in-law has a Hisun 750. It has started to not change gears while running. He can turn it off, change gears, then restart and it will change. I thought it might have something to do with the brake but can’t find any info. Thanks in advance for any info.
By sxr951
By Oldman
Ive got an American Sportsworks BD-200. I can’t get the ignition switch to work, but if I cross the solenoid, it starts right up. Runs great. Can anyone send me a simple wiring diagram for a switch and where the 3 wires from the switch go! Any help is greatly appreciated!!! Thanks!
