Got the piston pulled today to hone the cylinder.  My friend's coming over tomorrow or Saturday to hone it.
 Gonna go ahead and replace the piston pin and snap rings.
    • By redDance
      Does anyone know where to get beadlock rings that can be welded or mechanically fastened to stock uforce 1000 rims.  Totally for cosmetic purposes
    • By Jacob E freeman
    • By Browner010
    • By Fordman1
