customer got screwd Joke of the month!
By William P
After a short while of engine running the temp light comes on and the water in the radiator water is boiling., water level is ok pryer to starting engine. This is consistent. Coleman 400 bout 3yrs old
By diamondjfarm
Thanks.
By Joe Breaux
just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought a C FORCE 600 ATV to replace an old and well used Honda that finally after 18 yrs gave up a rod bearing. So far the new one has really impressed me .. I like the new Power Steering and this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas . It also has something I have never seen. Its EBS engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
