ok I read  about the guy with no spark, did he fix it? I have a 2012  Coleman outfitter  ut 500. I have no spark. I have replaced the coil, coil wire and spark plug, and still nothing. Any help would be greatly appreciated. Or a wiring diagram.
    • By Gorj
    • By Marie
    • By Grant
