Once i get the cylinder honed, the only remaining problem is the crankshaft shim..  And i have a few questions.
1. In the manual it gives a solution to the problem i'm having of the crank NOT spinning when the cover on (by hand).
2.  And i just can't wrap what's left of my brain around the instructions, i guess use a caliper to measure? (instructions  circled in red)
 (my brother has been helping me, he's fairly knowledgeable with this stuff, but more Diesel engines than anything) and he says to use a dial indicator set up, and to use this* as a spec for end play. and that would help us get the measurements needed in picture #2.
1st pic is the runout. But is it the same as crankshaft end play? 🤔
2nd pic is of the instructions (solution) to get the correct shim.
 I don't know, maybe this makes sense the way i wrote it.
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By BMurph
