By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By JSmojo
I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
Here are a few specific questions about them
1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
2. If you had one and got rid of it, what was the reason?
3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
By Grizz
Hello I have a 2022 axis 7004x4 Utv after about 6 months it would start fine but sometimes it would stall and you have to crank it again and it would run fine I am wondering what causes this does anyone else have this problem. Thanks
By Jacob E freeman
By Nickie Watts
I have a Hisun Strike 1000 I have been trying to get going, it has only 39 hours on it, so I can only assume it has been sitting for a long time.
The issue is it is losing spark to both coils after 20-30 seconds of running, doesn't matter if it's WOT or Idle, it will shut down. What sends signal to the coils to fire? It has a crank sensor, I was thinking a CDI box, but I have not found one of those on the machine.
The rear end was busted on it when I got it, So I ordered a new one and installed it only to run into this problem. I can only imagine the problem has happened over it sitting so long and not being driven.
I originally thought it was a fuel problem, so I checked the injectors, throttle body, o2 sensors. Discovered the heating element in one of the o2 sensors was bad, so ordered both and also replaced both injectors just to be sure, then discovered it is only losing spark.
