Need help converting
By FTG-05
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By rdborra
By CYJSP2009
Dear Friends,
2022 Brand new Joyner CV Axles and CV Joint rebuild kits are comming
1. S650.03.02.02.00 ---Joyner 650 Commando Rear
7. 14274 --- 650 ider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
8. 15803 --- 650 Sand Spider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
Price: CV Axle: USD250/ Piece; CV Joint kit (without grease): USD110 send to door.
Buy 1 piece: Get 5% discount,
Please kindly note Qty for each part is not big and it is hard to forcast when there will be next offer for these kind of products unless there is sufficient confirmed order qty for productioin arrangement.
Payment method: Payoneer payment link ( can pay through bank account or credit card) or Paypal ( [email protected]) . Payment commission paid by the buyer.
Interested parties, please contact [email protected].
Good Luck
Casey / Leaf Asia
July-07-2022
Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time. Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters? Almost acts like it might be clogged if so.
