UTVs represent a pretty good investment of both your money and your enjoyment. The tires that come stock on your machine are usually pretty good all-around tires, but there are several reasons to consider going for an upgrade. You might want a more aggressive tread pattern for a specific kind of riding. Perhaps the riding conditions in your area call for a tire with better puncture resistance. There is always the reason that comes from countless hours of enjoyment – the stock tires are simply worn out. Maybe you just want some different tires simply because you do? Regardless of the reason, a new set of tires represents a significant investment. Here are five of the best UTV tires for the money on the market today.
Read More
    • By SpaceGhost
    • By Duncan
      Anyone out there have a street legal UTV? Any idea how to get one registered for on highway use?
      Thanks in advance
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
