2017 Massimo msu500 efi no start
By weasel
By Bobby Courtney
I have a 2021 Coleman 400utv with 60 miles on it. I bought as project. It’s idled ruff and fouled plugs since it was new. I have removed and cleaned throttle body new injector new idle air valve new oxygen sensor. Installed ngk iridium plug. Starts and run good for about 5 or 6 miles and fouls plug. It runs rich all the time. I’ve done reset on ecu. I’m about to think it’s time to try a new ecu. Anyone please help.
By Sisco
By Alex
By Mike Turner
American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
