Would I be able to get a 700 head and piston to replace my 500? Or is it not that simple . Probably need a cam too? Anyone have info or ideas. Also remember reading somewhere about wiseco 11:1 pistons being compatible
 Stupid question but just wandering, why do you want to swap the head and piston?
 you can only get a new  (OEM) piston with a piston kit for the 500 and 700.  http://sportsmancountry.com/Massimo_Parts/CRANKSHAFT_PISTON_MSU500/     http://sportsmancountry.com/Massimo_Parts/CRANKSHAFT_PISTON_MSU_700/
the piston kits are the exact same part numbers, so i assume  they are interchangeable.
 here is the OEM cam http://sportsmancountry.com/Massimo_Parts/CAMSHAFT_CHAIN_MASSIMO/
I don't see how you can swap the heads to get more power.  The part numbers are not the same.  Crankshaft part numbers are not the same, either.
13101-004-0000-KIT Piston Kit, HS UTV 400/500
13101-007-0000-KIT Piston Kit, HS UTV 700
    • By SouthernGypsy
    • By NC4wd
    • By se3388
      Steve.............
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
