Can anyone tell me WHAT I bought??
6 hours ago, kenfain said:
There's got to be a manufacturer plate on it somewhere. It'll have the vehicles info on it. I'd get it up in the air where I could inspect the bottom thoroughly. I'm assuming you've inspected all that's visible on the top side.
Yep, I looked all over and no identifying marks anywhere. I’ll have to get underneath it. I have however discovered it’s not a 4 cylinder, it’s actaully a 3 which means  it’s a suzuki F8B (800cc) or at least a clone....
Looks like it would be a lot of fun to drive. But with those open wheels, I think you'll be wearing whatever you're driving through. You should also look for a stamped number on the frame. I'd think that it would be in the cockpit. Those numbers are hard to spot, since they're painted over. Good luck, and welcome to the forum.
I think most manufacturer's put the stamp below  or around the seats.
    • By MISTERTIRE66
      Recently inherited 08 joyner renegade r4 800.. seems to be sound mechanically but I cannot find bal joints. Any pone help with other replacement part number please.
    • By Paul Angstadt
      Paul
    • By diamondjfarm
      Thanks.
    • By mac66
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
