So im in some desperate need for help with this dam buggy that im trying to put a limited slip diff from wavetrac or peloquin in without completely getting new axles for it. The transmission used in this buggy is the 020 trans which i currently have in pieces trying to rebuild and install the lsd. So the problems im running into are the axle shafts on the new lsd. The differential originally was a solid spool with 32mm splines with a ball plunging cv joint. The new lsd is a 27mm spline and i cant find a ball plunging joint/ axle flange that will fit with that so it can still obtain the plunging motion necessary and use the stock axles. I have taken pictures of the entire setup, im either looking for a flange that will work with the axles i have, or a cv that will fit my stock axles. Any help would be great, and appreciative. I just want to get this thing finished and its the last step. 657033d16cb865b24413fb9a955999c2.jpg313ff0bb03aa6f29120263ce294aa7b6.jpge6a76b442057cfb6c5ac77e071c0d05f.jpg603fcbd4fb66a8c0e790c440466e620a.jpgf7901c272cecc72f17d7cf37b02ebe18.jpg76c3da28fb850c3b7189db77b0aaad84.jpg90f4260bc00bf3b9330cbc16a166ac37.jpg1dae095431a1aa617136ccb5246afc4d.jpgce20e4bb50fef0e697f7833f4517d982.jpg
Sent from my SM-G955U using Tapatalk
  • 4 weeks later...
    • By Wolfpaak
      Kenny
    • By Marie
