Register a new account
Sign in
    • By klm
      So here is my dilemma, I bought a 2014 Massimo MSU500 eleven years ago from TSC, its never been off the farm, had my share of ups and downs with it but never walked back to the house. I have bought a Kubota Sidewinder and it is a fine machine.Problem is I just dont need the Massimo and would like to sell it but the last thing want to do is sell it (cheap) to someone who doesn't realize what a POS a Massimo  can be and can't afford to maintain it.  I plan to put it of Craigslist with pictures and description, not sure how to warn potiential buyers without scaring them away.  I feel like it could be a great buy for the right person or a terrible buy for the wrong person.  I'm thinking $2500.
    • By Kingfish
    • By Ridge Runner
      i have a 2019 Coleman 550 Outfitter.  The tail gate has a pin on each side, that snaps into latch blocks that are mounted on the inside of the tail gate opening.  There are two M6x16 pan head screws(bolts?) that hold the latch blocks in place.  The screws enter from inside the bed body, and I can’t figure out how to access them.  This is right by the tail light assemblies.  I tried taking a pan head screw out of the fender lip, but found out there is not a nut firmly inplace, to hold the pan head screw in.  Bottom line I’m making it worse.
      coleman was no help.  If I could figure out how they attached the tail light, then maybe I could put the latch screws in through the tail light hole.  Any ideas?
      thanks
      Ridgerunner
    • Get More For Your Device
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
