silverbullet
No Problem  up to ECU.Seal wire plugs .They  all the plug in to the harness.the big two connectors do them.Snorkel intake and the 2 differential and any whear you see.Thanks Note this is not a everyday product.
Rich
    • By Grant
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By Kingfish
