Does anyone know what the recommended fuel pressure readings are for an 1100 Sand Viper?  I recently had the gas tank and fuel pump replaced and now the engine is very difficult to start and when first depressing the gas pedal the engine bogs down to the point of almost dying unless you quickly depress the pedal to almost full throttle.  The readings I'm looking for are.
1.  Pressure reading when key is turned on and fuel pump is engaged but engine is not started.
2. Pressure reading when engine is idling.
3. Pressure reading at full throttle.
Any information on this would be greatly appreciated.
50 psi at all times the ignition is on and/or the engine is running.  Electric fuel pumps don't rely on engine speed.  I can't see where the Chery 1100cc engine would need different fuel pressure based upon the chassis (Joyner Trooper vs Joyner Renegade vs Joyner Sand Viper); should be all the same.
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
    • By Duane Baker
    • By Sando
