Well I screwed up this weekend. I got my Pro FXT a little deep in the water and it locked up. I got it home pulled the plugs, sucked the water off the top #1 piston. (that was the only chamber with water in it.)The crank case didn't appear to have any water in it but I suspect it broke a piston or rod. I took the belt housing cover off and I cant turn it by hand. When I turn the key all I get is a click. It is now on its way to the dealer Ill give an update hopefully in the next week or two. SAD-DAYS for the pocket book!
Usually  clicking indicates the starter is bad or isn't getting enough juice. I would start by checking  the battery.
read through this thread:
if the battery checks out, i would replace the solenoid, or check for voltage AT the solenoid/starter.. as far as not turning it by hand, i *think* you are supposed to  be able to turn over by hand. but i am not sure on that aspect.
here's a video for the solenoid.
If you do find a broken rod here is a site for parts. Great business. https://www.kawasakipartshouse.com/oemparts/c/kawasaki_utility/parts
i guess this will help you out in someway or another. :D
welcome to the UTV Board
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By Flanman55
      2007 Hisun HS700  will not crank.  Replace the ignition switch. Same thing.  Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
      can anyone suggest something else.
