So bought the kids a strike 250 and we live close to some small dunes and the thing does not like sand with the stock tires.  I was thinking about a set of sandstars for the rear but having a hard time finding wheel specs on the 250? Anyone know bolt pattern and offset of the factory wheel?
Thank you Brad
Hello Brad,
Yes, the Strike 250 stock is a little underpowered. Do you happen to have one of the newer models? The reason I ask is because on my website we are able to unlock your ECU with the factory software, this allows you an additional 2000 RPM! As well as a higher top end speed. This will help you with the sand dunes as well.
As for the wheel specs, they are 4 x 156 on the front, and 4 x 115 on the rear. Check any Yamaha banshee or raptor site for wheels, as either will fit just fine.
Check out www.warriorsoffroad.com for a bunch of additional info for your Strike 250
Matt
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By camojay
    • By GaryC
    • By lowgear52
