Massimo 500 A arm noise
Racer310
Bought this UTV and the owner told me the A arms are making a noisy sound but he just took the bolt out re-greased it and tighten it down, band aid fit I think. I am wondering if grease fitting are suppose to be there. I guess I could drive to Tractor Supple and look at the new models.
I bought my Massimo in January, 1700 miles on it so far. No zerk fitting on the arms, but plenty of zerks in other places. Mine makes an occasional snapping/popping noise when I'm coming off a steep side load, only happens rarely. Only problem so far is a leaking front oil seal (passenger side) that I will be fixing tomorrow.
  • 4 years later...
    • By shepdog
    • By Goat Quilter
      We pout new belts cleaned engine and carburetor plugs you name it.  Drove down road no problem came back uphill no power won’t go . What’s the issue?
      could it be clutch?
    • By weasel
    • By hetovi
      Hey everyone,
    • By Polish DIY Lover
