I have a 2007 Joyner sand Viper 1100 cc that needs a clutch it is next to impossible to find one I have heard a Geo Metro or a Ford Escort 2.0 will interchange could anybody help me out with this
  • Confused 1
Silverbullet
I have 3 different ones.Stock 195.00 up grade 269.00 and kelver 399.00. Take your choice in stocks.
If you have an  need i have Hi Performance  parts.Ever part in stock if not i can get it from Chine call me if you need call me  for support.
928 344 2117 just call me
928 246 6819
    • By Marie
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
