I had been wanting to install power steering on my T4 for years so I went to the salvage yard last weekend and bought a complete column (minus airbag) out of a 2009 Nissan Versa for $125 with the ECU.
It was a fairly simple install. The long shaft that fits to the Joyner steering rack actually fit perfectly into the Nissan column. Had to weld up a U joint on the Nissan column to make it a straight shaft and fab up one simple bracket. Connect power and ground plus a switched 12v and now I can steer with one hand!
  • 4 months later...
I wouldn’t deal with SB...he is always a pain in the ass for some reason the few times that I have ordered parts from him and everyone on the forum that deals with SB reports problems receiving parts or just getting ripped off completely.
I will post some better pics as soon as I can, but I can tell you that the Nissan Versa column was simple to remove in the junk yard and the only additional parts I needed for installation on the Joyner was a 6” piece of 1/2” angle and 18” of heavy wire to run for power from the winch 12VDC connections.
Oh, and I did have to weld up a U joint that was part of the Nissan linkage, but it was easy!
  • 2 months later...
@mixfixdave  thanks for the pics, sorry for the late response. I hadn’t noticed you had responded back.
Right now im having problems with my trooper it wants to stall when I give it gas. So I’m working on fixing that currently.
thanks again
Scott
  • 8 months later...
  • 9 months later...
  • 3 months later...
Hello guys, newb here.
I own a 2004 Joyner Renegade R4 800cc and am wanting to add power steering to it and am wondering if the fix mentioned here would also work on my R4.
Kenny
    • By staind
      thanks Dan D. aka staind
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Cletus
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
    • By A P
