  • 3 months later...
  • 10 months later...
  • 3 years later...
I'm bringing this back to to the top.  I have a 2010  500 and would like to know before I buy.
Anyone have a definite answer on this?  Thanks
    • By Ductking1
    • By SouthernGypsy
    • By hisun junk
    • By Justine
    • By se3388
      Steve.............
