Starter on Ranch Pony 500cc burnt and already ordered 2 from BMS that are wrong size which is a problem returning for refund. Had same problem returning with one way bearing on starter clutch. Just wondering if anyone would know of a compatible starter maybe artic cat or honda or other.
Thank you for any help.
Just look on your original starter motor for a manufacture's name or a part number, then look up the part number on google and buy it from any of the vendors that come up BMS is usually way over priced.  I have a ranch pony and have really good luck with it but most of the parts from Chinese side by sides use the same parts
  • 4 weeks later...
  On 10/12/2024 at 12:50 PM, Joe Breaux said:
Have yours rebuilt
Expand
Agree with this.
Rebuilt from local, reputable shop is good for local economy and you get better workmanship 99.99% of the time.
10 or more years ago, was needing a replacement alternator for car. After getting 3 or 4 from auto parts store that didn't last 1-2 months. Thankfully they had 6 month warranty. The last one I got, I took straight to the rebuild shop. Cost an additional $50 but lasted until I sold the car 2 years later.
    • By bms stallion owner
    • By The Road Hound
      Hi,
      New to the forum.
      Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS.
      I'm between 3 brands and 3 models:
      *Kawasaki MULE PRO-FXR   1000.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
      The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By allinone
