Good morning,
I am new to the Hisun world.  I am trying to track down the part pictured in this post.  Can anyone help me out?
I just picked up a 2010 Strike 800  that I intend to set up with hand controls so that my disabled son can use it on dirtroads, etc.
Mike
  • 2 months later...
  • 2 years later...
Hello Strike 250,  I saw the post and realize the date makes it a little stale but I have a module that is like the one in the picture by Newbie. The description on mine is
HSUN800DC SANXIN M100401   My problem is the machine starts runs great but at times it will stall and it will not start. You can hear the fuel pump but it just turns over and will not start. Left alone for a couple of hours it starts up but will continue with the same problem.
Any ideas you could share would be appreciated
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By Roadstar515
      Regards, Rick
      Hello All...
    • By fikey
      I am considering a Hisun 550 for tooling around the farm> I have a Kawasaki Teryx 4 and deeply disappointed at the difficulty of getting to the engine and belt for repairs. I would like some feedback on the Hisun's reliability and ease of access to work on. Thanks.
    • By FDWT9956
