Good morning,
I am new to the Hisun world.  I am trying to track down the part pictured in this post.  Can anyone help me out?
I just picked up a 2010 Strike 800  that I intend to set up with hand controls so that my disabled son can use it on dirtroads, etc.
Mike
  • 2 months later...
  • 2 years later...
Hello Strike 250,  I saw the post and realize the date makes it a little stale but I have a module that is like the one in the picture by Newbie. The description on mine is
HSUN800DC SANXIN M100401   My problem is the machine starts runs great but at times it will stall and it will not start. You can hear the fuel pump but it just turns over and will not start. Left alone for a couple of hours it starts up but will continue with the same problem.
Any ideas you could share would be appreciated
    • By Poppateets
    • By Frank in MI
      Thanks for accepting me!
    • By hisun junk
    • By SouthernGypsy
    • By Justine
