I have a nordik 700 k that is over heating and it seems the cooling fan is not working but checked it on a battery and it works fine. When I got home the antifreeze was low but filled it up and see no leaks but noticed the reserve tank was full and it did not take any from it.
    • By Jacob E freeman
    • By A P
    • By Will Sutton
    • By mark walkom
    • By amiracle40995
