Hi from Mid-Michigan - working on my first UTV
Picked up an essentially new 2022 UT400 with 9 miles on it. Decided to change the oil because it's probably never been done. Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out. What should I start checking?
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Ductking1
By SouthernGypsy
