Transmission Fluid Leaked out? Why??
KTMspeedFreak
For some reason, out of no where all my tranny flue is leaked out from around one of the seals in tranny where the drive shafts come out.
Buggy was in the garage for few days with no leaks, then randomly all the oil just started dripping out from one of the seal areas?? I didn’t even move the buggy... The only reason I can think as to why it went from zero leaks to major leak is the cold weather here in FL may have shrunk the seals?? Anyone else think this is rather strange? 🤨🧐
Also, antonella’s know where I can order these?
  • 4 weeks later...
I took some pics... As you can see the right side axle/cup/hub whatever you call it is able to move side by side and when it moves all my fluid dumps out. The other side I cannot get to move whatsoever so I feel like this isn’t suppose to be happening and perhaps a nut/clip or some other restraint is suppose to hold this in place?? anyone know how these work or what might be missing?
Your description of the end play also leads me to believe there is a snap ring or some kind of retainer that's missing.  Pull that axle out and look for a groove around the shaft that goes into the transmission.  If you go to this website:  http://joyner-usa.com and click on the "Manuals" tab, you'll be presented with a list of some Joyner UTVs.  Pick one closest to  your model.  There isn't too much difference between the year models or even between the Joyner Trooper & Renegade (with the 1100cc engine).  The drive trains are fairly similar.
    • By dman66
    • By Charles Hamilton
      **Disclaimer: Yes, I know Polaris and Kawasaki are SOOO much more better, reliable, retain their value, not made in China, etc. I need a UTV and don't have the money or financing for one of those units, so let's keep this discussion productive please**
      Hi all, learning about my new T-Boss 760 from TSC, and am trying to find the actual dip stick to check the oil, funnily enough.
      Does anyone have a picture of it or something? It's crazy that I can't find it...yet here I am.
      Also - any advice on oil? Manual says 15W/40 "SJ" but I'm told the SJ spec doesn't exist anymore.
      Gentleman at TSC said to use any 15W/40, but I'm very nervous about causing an issue this early on by using the wrong oil.
      Anyone have advice?
    • By Browner010
