Fuel pump runs but nothing is getting tô it. I tried putting a vacuum on the outlet hose of pump and it wouldn't pull anything. This machine sat for a year and a half unused. Is there a way to prime the lines?  What could be the cause of the fuel not getting tô the pump?
Rock on...the Joyner is awesome. Can’t tell you the times I have hauled one of the Polaris guys back to get their trailer because of a broken axle. My buddies call it the family truckster!
Just took a short ride about town and along the railroad trail here in Tennessee...have tags on mine.
Can you connect a fuel pressure gauge to see if it takes a long time to build fuel pressure?  Could be a fuel pressure regulator leaking internally or the fuel pump itself not providing sufficient pressure soon enough (slow build up of pressure).  On  my Renegade (same engine as the Trooper), I have to wait about 5 seconds  with the ignition on before I can start the engine.  That gives time for the computer to boot up and  the fuel pump time to build up pressure (I can hear the fuel pump run  for about 4 secs, then turn off).
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By PossumTruck
      Greetings,
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
    • By Fordman1
    • By Robby
