  • 11 months later...
      ย
    • By ned
      I have a Kubota RTV -X900 that I recently got from someone that is in good condition.ย  I'm trying to determine what year it is all to no avail.ย  I have the 16 digit product identification number and have gone on line to multiple sites with no luck.ย  The number is A5KB2FDBCFG024444 .ย  I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit.ย  Thanks in advance.
    • By SpaceGhost
      ย
      Just picked up my first side by side a couple days ago. A 2020 Can-Am Defender HD10 DPS 6x6.ย
      ย
      It's in pretty good shape, but as you can probably tell, it's sitting a bit high. Former owner put a lifting collar on the shocks.ย
      ย
      The good = almost 17" of ground clearance. (30" tires)ย
      The bad = incredibly steep driveline angles, and a pretty stiff ride.ย
      ย
      They will be coming off.ย
      ย
      Other than that... clean as a pin and appears very well maintained.ย
      ย
      Looking forward to seeing what this forum can bring, and hoping I can bring something in return.ย
      Hello All...
      ย ย ย ย  Just bought a 2014 Massimo 500 UTV.ย  It;s not running at the moment, but hopefully will soon.ย  I need a seat for it also (passenger side, if it makes any difference.)ย  It is a crank-but no start situation.ย  Just now starting to read the boards for solutions.ย  Apparently these models are well known for this issue.ย  If anyone has any suggestions, please feel free to chime in, it would be greatly appreciated.
      Thanksย
    • By Tarak1980
      I have a Coleman HS400UTV-5 got it manly for hunting and spending time with the grandkids
      The one problem I am trying to avoid. My son borrowed it last summer and said it ran hot so he added water to it . I do not know how much he put in so I would like to drain most of it and add new coolant to protect it this winter. I can find no drain cock or any way of draining it besides loosening a hose.ย  Any suggestions ????
