    • By Rick McGill
      I thought the problem was electrical but I just found this in the oil filler tube. Does anyone recognize the part? I know I'll have to tear down the whole engine, and maybe I'll find the rest of it in there. Something beg enough to seize up the engine. That was the problem I was trying to diagnose.... 'Cause it's locked up.
      Rick
    • By Travis
      History of the MULE.. i had to zoom in a little bit to read it.
      https://www.kawasaki.info/pdf/UV&RUV_HISTORY.pdf
    • By Travis
      The weather fooled me again... I'm ready for it to warm up and stay warm.
    • By 2scoops
      So while building my cage I made one bend a couple of degrees over. It was literally 3 degrees off. So I wedged it in my tube bender, had my wife sit on it while I pulled like hell, and several attemps, and got it within one degree. So with my wife (130lbs) and me pulling my 185lb ass off all it left was a couple of small dents in the 1 3/4 .095 wall hrew I am using for half of the cage. The other half is .120 wall DOM.
      So once I got done getting it to shape I thought to myself that I need to see what happens if I try it with the stock cage. I wanted to know if all this effort is worth it. Well, I finally got around to it today. This is what happened with just me pulling (no wife for extra leverage) and with half my effort:
      If you ever had a endo in a trooper you would not walk away. Can it handle a flop or a slow sideways rollover... Probably, but an extreme impact and it will wrap around you like a street taco.
    • By Tinman
      Wait till you see this!!!
      YOWZA.
      Where can I get one of these???
      Do I have to be a JEDI to get it?
      http://www.nbcnews.com/technology/futureoftech/hover-bike-lets-you-drive-jedi-956125
