  • 1 year later...
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • Guest
      By Guest
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
    • By Wolfpaak
      Pink Floyd quote/reference.
      i am looking for a starter for my 2004 800 Renegade and apparently the place I dealt with before is no longer in business. Any help?
      Thanks in advance,
      Kenny
