Massimo 500 Throttle Pedal Extension needed
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load. Light consistent throttle on fairly flat ground no problems. If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc. Floor it or let off and it may do just fine. Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel. So far doesn't ever completely quit. If you let off it will idle just fine. A lot of times if you floor it, it will pick up and even get a boost of power. Changed to a slightly hotter plug to see if that would make a difference, but it didn't . Any ideas what might be going on and what to try next?
By TexAcoon
I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
By Guest
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
By Richard shepard
I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
