      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
    • By Bryan
      Just wanted to share a few photos of some recent mods. Heat shield photo was taken before lift was installed. Still have heater, overhead console wire harness and snorkel kit sitting in the garage that I need to get installed.
    • By Bryan
      Thought I would share today’s activity!
    • By Murph
      I have a 2015 ranger 570 added an inferno heater/defrost and now it overheats any help would be appreciated
    • By rocmoc
      A added benefit to the expanded metal engine cover is I can lay my take-out Pizza box on it for the drive home and the Pizza is still hot when I get home. LOL! It really works. This is my test to see if the heat is venting off of the engine.
      rocmoc n AZ/Baja
      Super Super Double Dupper Moderator (self proclaimed!) LOL!
